1 - 2 of 2 Posts
Hello,
I got a leak from the clutch master cylinder on my 2015 scat pack challenger ?
I assume I need to remplace it ? Any advice for that ?
I didn't notice any issue with the clutch. Could it be the sign of an other problem anywhere, for exemple the clutch disc reaching its end of life (slimmer, so the master cylinder could be at the dead end) ?
Thank you in advance.
There was another member here that had issues with his clutch master cylinder which happened right around the time where he removed the clutch delay valve. As for how to remove and install, check out the online chilton manual.
1 - 2 of 2 Posts
