Clutch pedal switch
5286 7
I been online everywhere looking for a clutch pedal switch and cannot find one
I also wanted to know something I just looked online and saw that the push button I saw looked like it fit my ignition will I do anything else or just buy the button and put it in
Welcome to Challengertalk ;) Tell us about the car, maybe the members will have some answers for you
Assuming it is +2015 (did not check earlier years to see if they were the same), I think the switch is sold as an assembly.
Rockauto shows some pics.
Even the FSM seems to show the switch is integrated with the clutch master cylinder. Do you have the old one out and in hand?
997486
If you don't want to spend a lot on a new clutch master cylinder you might be able to jumper the clutch interlock signal but then you run the risk of the car being able to start with the clutch engaged and in gear.
997487
If you have a 2009 RT then this should fit.
To start it I think you will need to jumper pin 2 to pin 3. Not sure if PCM is looking for an open or a short to ground to start. To be honest for $88 I would just get a new master clutch cylinder.
Or you can get it cheaper at rockauto.
997493
Use the link here to access the online chilton's manual to show you how to replace.
Ok so according to FSM with the clutch fully released you should see continuity, with it depressed it should be open. I wonder if you just disconnect the switch if the car will start?
997496
Oh and on 2009 it looks like the switch can be separated from the master cylinder and you can buy it separately.
997497
was looking why my dodge challenger was not starting, they parked it in my dryway and never started again, have changed all relays, fuses, starter, master key, battery and the car was ready to start, gas pump was runing, jumped the starter an car starts no issues, for some reazon the relay sends the signal to the starter but gets interrupted before starter. so what you tell is the same sympton I got. Was troubleshooting in another post, with the help of others friends, and finaly getting to this point, the only thing between the relay and the starter is the Clutch sensor as the dyagram says, "Hope" I will check it tomorrow. just check or bypass the sensor and see if it works.
the issue that confused me was that the relay send the signal but too short, barelly gives a pulse. but not strong enough.
thank you!
