Spec or Ram,Organic, fiber or full metallic.
Clutch was feeling all spongey,it's at the dealer on the lift,which should I order?
I have the SPEC clutche on both of my Challengers. I am very pleased with the performance of the SPEC clutch. If cost is an issue, the RAM clutch is less expensive.
SS-trim with carbon graphite disc.
as GA said Spec is a very good unit and go with the 900 unless you plan to do heavy mods and high HP
That's the unit on my Challenger. It is rated at 900 ft-lbs of torque.
The SPEC clutch performs very similar to the stock clutch. The springs are stiffer but you will get used to them after driving a few miles. The SPEC clutch will also take a beating and not fail.
I went with the Spec SD80PT. Stock clutch was fine just wanted to be prepared.
