I've had the code for a little while. I thought it was a fluke at first, as I didn't notice any performance change. I cleared it and it came back with a cylinder miss in that same #4. I haven't noticed any performance issue at all... Could have been at start. I pulled the injector plug and checked it with a node. Fires good, so not a bad wire or computer. Anyway, I decided to just do a simple check to see if it was the injector itself. I swapped it with another cylinders injector to see if the code followed that cylinder.. Cleared the code, and drove. Code came back for bank 4... Now, I'm pretty sure, I didn't put it right back in the same spot, but, lmao, not 100% because I got distracted right in the middle of doing it, just like every damn thing I do around here.. Can't just do something, gotta stop in the middle to help someone else... Anyway, again, pretty sure I swapped them.
What else could it possibly be?
I'll get the actual codes in a minute and edit the op. Now it seems to be a few more related. But it's bank 4....
