Yes, you are correct...when the engine bay temps reach roasting levels, it pretty much bakes through anything/everything in there, where cold air might chance to pass through. I, too, went down the path of employing insulation to major exposed intake tubing surfaces and the IAT. The engine heat can still eventually get through, but the heat flushes out a whole lot easier when you actually put some flow through it than when it was bare. When it was bare and temps got up there, it was pretty much a permanent condition until a "full night's" cool down.
I wanted to further experiment with insulating the intake runners on the manifold, but that seemed like a major task to achieve. If you look/feel on the underside of the plastic manifold, you can see they packed it with foam insulation there, too. I presume that shields the bottom of the intake from the unadulterated engine block heat (probably quells some engine noise, too, if you can believe it could possibly be noisier
Oh, that reminds me to get back to my original point- all the CAI in the world won't help, if the tubing that leads to the engine is baked hot enough to turn it into warm air anyway, right?
