41 - 60 of 109 Posts
2010 R/T Classic 6M
And if your car has 50,000+ miles i would definitely consider new lifters. Every shop I called recommended I got new lifters even though i have a 6 speed just because you don't wanna risk flattening a lobe on you're brand new cam from old lifters. Besides it's easier doing the springs with the heads off. It'll cost you about $500 more after the price of gaskets, bolts and lifters.
Or just get a threaded rod, nut and some washers from hardware store with the same thread as in the crank. Although I would highly recommend renting the tool from you local car parts store.
2014 R/T Blacktop
Discussion Starter #43
Ok. So now I need new rockers. Geez. Ok. Any recommendations? I mean since I'm spending the kids college fund I might as well go all out here! :ROFLMAO:
FYI there are companies like MMX and I think Cometic (sp?) that sell gasket kits for cam swaps. I left the heads on because if I had to pull them off I would just yank the motor which would probably snowball into me wanting to throw in a forged short block.
2010 R/T Classic 6M
I couldn't find the right tools anywhere which is why I got creative. It worked flawlessly tho, just leave the heat gun on it for a minute or two and slip it on
2010 R/T Classic 6M
Lifters, not rockers. How many miles do you have? Definitely go with the Mopar non MDS lifters (same as what you have now)
Not rocker but lifters. Not 100% necessary but a good idea if the engine has high mileage.
2014 R/T Blacktop
Discussion Starter #48
I used the Manley pushrods for my 392 cam. They were the cheapest I could find and great quality. The valve spring tool I used was from hemitools. Most of the install is pretty straightforward but a tip for putting the crank balancer on without the installation tool, get it HOT with a heat gun and it should slide right on, enough so that you can use the crank bolt to tighten it all the way.
Thanks for the tip. Honestly I have no idea what a crank balancer is nor how to use one. I'm gonna add that to the long list of things to research before I start the swap.
This is the first major auto project I have ever undertaken. So I'm very new to the terminology and processes.
2010 R/T Classic 6M
The crank balancer is the crank pulley, what the accessory belt rides on at the bottom of the engine. It's press fit so you need either the special install tool which is essentially a longer version of the crank pulley bolt, or you can heat it up so it expands and slips over the crank snout enough for the crank bolt to reach enough threads. Make sure you replace both the crank and cam bolt as they are torque to yield.
2014 R/T Blacktop
Discussion Starter #51
Something like this?
2010 R/T Classic 6M
Looks like it, you'll need 4 sets of lifters (16). I'm not gonna say you 100% need them but at almost 80k miles I personally wouldn't risk it, I got new lifers at 58k miles and the shops told me anything over 30-40k is pushing it.
2014 R/T Blacktop
Discussion Starter #54
FWIW I listed the tools in my thread
I've been reading your post alot. Havent even made it all the way through. Pretty indepth and detailed. A big help!
What does FWIW mean?
And Dakbuilder's thread helped me when I did my swap. :)
2014 R/T Blacktop
Discussion Starter #57
For a complete newbie to all this these forums are like gold! I'm finsingnout stuff I never knew, and finding out more stuff I need to buy to get the job done right. Skip shift eliminater came in today.
Actually if you are going to tune the car for the cam you don't need the eliminator, and you can completely remove the solenoid from the car.
I have the solenoid unplugged and just got the correct socket to remove it but have not had time to crawl under the car to remove it and install the plug.
2014 R/T Blacktop
Discussion Starter #59
Awesome. Good to know. That saves me 20 bucks i can get back. :ROFLMAO::ROFLMAO::ROFLMAO: after the hundreds I have spent already!!! Oh my wife is gonna kill me!
Well a SC is thousands so better start breaking-in the wife. With the cost of my RT and its mods I am still a couple thousand short of what we spent on the wifey's JGC Overland. :)
