21 - 40 of 40 Posts
Discussion Starter #21
You can get an MDS 6.4 Cam for +$200
And performance springs are $5 a piece ($80 total)
I don't think you would have to swap out the MDS lifters as they are the same used by the 6.4. Although I would still probably deactivate MDS in the tune.
So all you need is timing seal, oil pump tube seal, valve cover seals (seals not really necessary) and the valve spring tool which can be had for ~$150.
Total would be well under $1K. But it is tedious work.
I'm actually looking up prices for all of those parts right now. I'm intrigued.
Can you help point me in the right direction for an affordable valve spring remover tool? All I'm seeing is "Hemi specific" tools that cost about $200. Also, any other parts you can think of that I would need, or is that it?
Bought mine from snap on.
As for parts, can't think of anything else.
I just priced it out, and the parts to do a 392 cam swap is only $323. lol
Well don't forget the tuner and tune. HP tuners is $300 ($550 for pro version), unlocking the PCM is $250, two credits is $100 (if you want the trans tuned it's like another 4 credits) plus whatever a tuner charges.
Discussion Starter #25
I already have a Predator--it's the old one, but it still accepts custom tunes. Just trying to figure out how much a mail in tune would be. A local shop does custom dyno tuning for $400. I just don't want to keep paying $400 every time I change something. I can't afford to do everything all at once. lol
I may be doing a 392 intake manifold swap eventually and a couple other small things.
If you can find SP or SRT exhaust manifolds you would have one budget power package. Granted it is a lot of work but if you do it yourself saves you some significant coin.
Discussion Starter #27
Yea, I actually bought some used JBA shorty headers, a used R2C CAI, the tuner, and a used 2800 stall converter all for about $500. I’m a good deal finder lol
I am trying to decide which route I want to go after my car is paid off. I was quoted 12k for a "Big Daddy" cam at OST Dynos. I am basically looking to get rid of MDS, have a nice idle that does not require a Torgue converter and get my car into the mid to low 12's. Is this possible? Would love to go into the 11's N/A (sleeper).
12k for what?
To add more to the confusion, theres actually Two camshafts labeled for each stage, hence theres actually 2 Stage HRT camshafts, very similiar, so close in profiles..
Im trying to research
To do a budget 392 cam swap in a 5.7 just requires the cost of the cam (~$220) and mopar performance springs (68277306AA is the individual part number at $4.33 each ~$70 total). Although the spring tool cost from snap-on is about $150. So you can see the hardware is pretty inexpensive. Although I would highly recommend getting comp cam push rods which are better quality than stock.
Discussion Starter #32
Yup, and the required gaskets. Comp Cams just came out with their own tool that’s $130, so I bought that.
Only gaskets I really needed was the oil pump o-ring, timing cover and a small tube of RTV. If you plan to swap the springs while the heads are in the car, might be worth to get a couple of spare valve keepers from the dealership as well. Once they hit the floor they tend to disappear like cockroaches.
Where did you find that valve spring price and application? Best price I’ve seen is around $10 each. This really sounds like a nice budget project.
Welcome to Challengertalk ;) Shipping makes the difference. Steve White has the cheapest to CA
Add VIN# in cart to confirm fitment. Use discount code: CHA1 at checkout
Following..
Being a newb to these engines and cams that are semi-adjustable timing wise( I’m an sportbike engine builder/repairer so no stranger to valve timing), do most good tuners take full advantage of cam tuning? Are most factory 6.4 cams installed in 5.7s full valve timing control or are limiters needed/used? Why would aftermarket cams require limiting the range of movement? Aren’t they leaving some hp/tq on the table by not taking advantage of it? How do you go about checking piston to valve clearance in one of these things? I can’t imagine not being to know exactly how much clearance there is. I think I’d really be sweating it the first fire with a new big cam, praying everything is where it needs to be so there’s no contact. Just some random thoughts...
At idle/start-up the cam is full advanced and there is nothing you can do about it. Take a look here for info how VVT works, but in short it is controlled by a solenoid that receives a PWM signal that fills the phaser with oil pressure to retard it (a clockspring keeps force towards full advance ).
The cams are generally set-up for smog (are set-up for EGR effect) but the tuning school claims there is some power on tap at the high end.
VVT not working properly with aftermarket cam. (article talking about EGR effect)
Aftermarket cams generally have higher lift which is the reason for phase limiting or locking. As for how do installers know what is safe in terms of clearance you can reach out to some tuners on the HP tuner forum but companies like comp cam specify whether phase locking/limiting are needed.
BTW check the VVT section in this post to see how aftermarket cams are set-up when using HP tuners.
Great info there. Thanks for taking the time to post it.
Isn’t there a Chrysler engine that has the intake a and exhaust lobes separated? It let them alter the intake and exhaust lobes independently. Sounds expensive but I thought these engines had that feature until I bought this car and started looking around.
21 - 40 of 40 Posts
