Today I am finally connecting my a-pillar Autometer Boost & wideband gauges.
Can anybody share how you connected yours? More specifically where and which wires did you tap in the factory wiring to get accessory/key switched power, parking light input for lighting and where did you exactly run your wires & vac hose thru since you got one big connector that has to go through.
Greatly appreciate any shared info.
Thanks!
09 RT Challenger auto
Driver side at the fire wall theres a 1in rubber grommet I ran the wideband through. Removing the panel under steering wheel make it easy er.
Here is a similar thread on the wideband that might be helpful. Also check the Knowledge Base section on the LX forums.
Checkout Speedy's Garage he did a installation on his Challenger with video.
Speedy's Garage
Thanks for the info & links. Very helpful and greatly appreciated!
