1 - 15 of 15 Posts
Hi guys just need help can anyone tell me what kind of coolant for 2016 challenger scat pack. I have a pink color. I need to add but I don’t know what kind. If you can send me a link so I can get the part number. I know what I only can use a pink color coolant. Thank you for help.
994268
Your coolant was originally purple - the dyes fade within a years' time and ends up pink. My '16 had Cool-Aid purple coolant color and by month 10 it was fading to a pink color.
there's two versions concentrate or 50/50 ready to use. If you get concentrate, you just dilute with distilled water to a 50% solution
68175336AA Concentrate (OAT)
68175337AB 50/50 (OAT)
So if I want to add it some. Is it ok mix with purple? Thank you for good information.
yes its the same coolant your original had faded from purple to pink.
I see Hellcats all the time where there's two separate systems - the intercooler circuit and the engine circuit.
The intercooler coolant remains purple and the engine coolant turns pink. It must the the iron block or the higher temperature that makes the dye change color. The intercooler would be only aluminum parts its exposed to
Funny thing, My 2018 PCP has purple, my co-workers 2012 YJ has yellow.
2 for 2 on coolant matching car, both with 392
No coolant needed, just add a little distilled water.
Reactions: Parrott_350
Not familiar with those part numbers.
These numbers I know are right,
68163848AB concentrate
68163849AB diluted 50/50
2012 is HOAT, 2013-up is OAT.
2011 392 SRT, 2010 R/T Classic, 2019 R/T Plus, 2016 SXT Plus
Agree.
Then the OP needs to find the coolant leak. I'd start at the water pump seals...
Could have been from a 180 thermostat swap without using a bag to catch the antifreeze.
You could argue that once the distilled water is in the engine its no longer very distilled - and add tap water. So far, its not caused me, or rather, my cars, any issue.
2019 M6 Scat Pack
What? Adding distilled water is standard procedure for a small coolant top off. Tap water has minerals and other crap in it.
This is excellent information :
"Not familiar with those part numbers.
2012 is HOAT, 2013-up is OAT. "
Thanks Slidd, I appreciate it ! ( Good for your Jeep also ) (y)
Best regards
parrott
If the coolant system is being refilled from a drain & fill/flush, and the next expected coolant service is at the end of the new coolant’s service life (3-5 yrs or 50-100K miles), then yes, using anything other than distilled water could cause problems later down the road.
However, it takes a long time for OTD (Other Than Distilled) water to lead to problems in a coolant system, so adding tap water to a system with coolant halfway through its service life, especially for the purposes of topping it off, should be fine.
If the system’s coolant is still relatively new and has several years worth of operation to go, and if a significant amount of water is needed to bring it up to full, using tap water would not be advisable IMHO.
1 - 15 of 15 Posts
