1 - 12 of 12 Posts
2011 SXT
Alrite so i have a quick question. I saw my coolant level is low so I was wondering.wen adding coolant am I supposed to wash it out ir can I mix the new with old?
Depending on how old the coolant is might be good to drain and flush the old then refill with fresh coolant not that huge of a expense...
What year is your Challenger? You should add coolant to the proper level unless you are due for a change. Don't drive your car if the level is low. Model years 2008-2012 use HOAT coolant that require replacement every 5 years or 102,000 miles, whichever comes first. From 2013 on, Challengers use OAT coolant that is good for 10 years, or 100,000 miles, whichever comes first.
1007237
Discussion Starter · #4 ·
Its 2019 rt..so I can mix it?
Yea mine is a 2019 so I got OAT some purple looking one
2021 JEEP Wrangler Unlimited Willys 4X4
2011 SXT
In other words depending on age of the car and mileage on the car if not super low on fluid take to a local shop and drain and flush the cooling system and refill to full amount with fresh Anti Freeze / Water so it keeps contaminats out and scale deposits hence better for the engine and cooling system .......
Since your Challenger is a 2019, your coolant is good until 2024 (5 years) There is no need to flush your system now after only 1-2 years. Just top it off with a pre-mix of OAT coolant and distilled water.
2016 Scat Pack Shaker
The coolant system section of the Challenger owners manual is excellent. It specifies simple checks and observations to help determine when maintenance is required as well as very specific guidance on coolant selection. It is well written and easy to follow.
10 year / 150,000 mile coolant....
1 - 12 of 12 Posts
