41 - 42 of 42 Posts
Yep, 6-10k.
Curious if any one has changed the color of their Challenger and how much did it run?
Also, Those that have had flames or graphics done on the original paint, how much was it and what did you have painted?
Thx
My car is in pretty pristine shape for a high mileage, daily driver. When I was having some work done and asked how much to repaint it the SAME color, it was 6 grand.
These days the car is NOT just sprayed with all the removable panels still in place, they all have to come off for some reason, multiplying the cost by times 2 or more. Each sprayed alone in the booth. Then re-installed. This one shop wants to take apart the door interior trim panel, windows, regulator, everything down to only the steel door, then paint it, & install new rubber. After every removable panel is removed and sprayed separately, then they roll what's left of the car into the booth. Then the BIG re-install starts. Alignment, getting right. So it's a deal at $9K. Tons of mechanical work & new gaskets.
This is with the plane stock (best quality PPG materials) paint job. One coat pigment, one coat clear.
41 - 42 of 42 Posts
