1 - 13 of 13 Posts
I've been searching on here and can't seem to get a firm handle on all the different combo's we have.
And GOOOGLE sucks by the way keep getting wikipedia BS.
I would like to get a idea on the different size cranks there are. I'm a newbie to these newer Mopar engines and don't have any idea and can't seem to find the info anywhere.
Also what would be recommended for bore.
I thought this would be helpfull info for anyone wanting to do a engine build like myself. Thanks guys:thumbsup:
just buy a BES motor and be done with it forever
oh yea and a Kenne bell
They are on the short list for sure. Just want info on what stroke if any might just stay at 6.1. A list of what's out there is what I'm hoping for.
As for KB Jim needs to do some PR first.
All info I am posting refers to the 6.1 block and not the 5.7.
Available cranks
OEM: 3.579"
Scat: 3.795"
Manley: 4.05"
Compstar: 4.05"
K-1: 4.08"
K-1: 4.25"
Available Bore sizes
OEM: 4.055"
Anything between 4.055" and 4.09"
We use 4.06" as it ensures that the 4.055" bore is completely cleaned up and straight. If the block is scratched, sometimes we use a 4.08" bore if necessary but we never use the 4.09" bore.
PWR 6.1: 3.579" stroke x 4.06" bore
Mopar 392: 3.795" stroke x 4.055" bore
PWR 393: 3.795" stroke x 4.06" bore
PWR 419: 4.05" stroke x 4.06" bore
PWR 423: 4.08" stroke x 4.06" bore
PWR 426: 4.08" stroke x 4.08" bore
Indy 426: 4.05" stroke x 4.09" bore
Arrington 440: 4.25" stroke x 4.065" bore
PWR 440: 4.08" stroke x 4.145" bore (sleeved iron block)
Thanks for taking the time time to put all this in here Andy:thumbsup:
It will be nice to have all this info in one spot for a refrence.
What is the stock 6.1 cylinder thickness we can apply to the bore sizes so we can get an idea of where you net out?
Just curious about the Mopar 392. Is the one listed the 2011 or a crate motor?
I thought they new one was going with a bigger bore and shorter stroke 4.09x3.72.
Great info. I have been doing the math in my head, but I don't know the chamber displacement, I was guessing it is about .75ci or so.
http://www.media.chrysler.com/dcxms/assets/specs/2011_Challenger392_Specifications.pdf
Ah, you missed a key point in my post. All of those bore/stroke combos are with the 6.1l block. The new 392 is using the new 6.4l block, but you are correct on the bore/stroke of it.
Cool, I wasn't sure if they were using a new block or boring a 5.7 or 6.1. I'm also wondering if the 6.4 uses the same heads as the 5.7?
1 - 13 of 13 Posts
