Hey all,
Any ideas on where I can take this to be fixed? I don’t want to do it myself. I’m afraid I will screw it up and it will look ratchet 😂
1013665
An upholstery shop might be able to fix that for you. It’s not too bad to do yourself, there’s a thread on here somewhere detailing several methods for addressing that.
The Adhesive gives out in that Spot I tried Double Sided 3m would hold for 2 days then lift so I made the Trim Plate.
Sadly that's a common issue mine is doing that I fabricated a .018" Stainless Steel Plate that clips in the Vent Top and holds it down.
bought the 1 1/2" piece at a Hobby Shop made by K&S it was 12" long cut it down folded it over friend is going to custom
Etch it with a Sand Blaster soon so it says SXT on it...
See if you have an auto vinyl repar guy in your area. When I supervised a dealership body shop we used a vendor who was mobile and did amazing things with dashs, seats and trim.
Mine had started to do that. I just popped those vents out (they pull right out) - then just used a superglue and glued the dash piece down - set some weights on top of the dash for a few hours while it all dried solid. Then popped the vents back in. That was a year ago and it is still solid and looks perfect.
1013710
