1 - 3 of 3 Posts
This issue is getting worse by the week. The dashboard around my center AC vents has swollen. Starting to happen around the other AC vents as well. Is a solution popping off the vents and using something to glue it back down? If so, best adhesive product to use and best way to remove the vent without snapping it? Thanks for any opinions.
remove the vents and glue down - there's a plastic structure underneath - just have to glue it back down.
The vent clips might break off - so be prepared in case you have to replace them. Plastics can get brittle, especially after many years and hot weather.
Reactions: Hoghunter
1 - 3 of 3 Posts
