DBA 5000 SERIES FRONT ROTOR RING REPLACEMENT 2015-2018 392//6.4L/6.2L CHALLENGER/CHARGER W/ 6 PISTON BREMBO
Chris
To Order: DBA 5000 Series Front Rotor Ring Replacement 2015-2018 392//6.4L/6.2L Challenger/Charger w/ 6 Piston BremboDBA 5000 Series flat discs are designed specifically to replace just the rotor ring in DBA and other popular two-piece rotor configurations.Crafted with high-carbon iron and cured with a patented process that reduces metal stress, the rotor edges feature 3 paint marks which change color to reflect different levels of metal temperature, and 144 pillars between rotor faces provide faster cooling and greater strength to reduce heat warpage and extend life. Recommended for use with performance modified street vehicles. Sized to exact OEM dimensions for easy, bolt-on replacement without modification.
Sold individually.
Chris
