1 - 13 of 13 Posts
Hello all,
Several years ago, I had a Magnum R/T and drove it in the shiftable automatic constantly. When I would come to as top, I would let the RPM's fall from whatever gear I was in, and would have an incredible sound of rumbling through the exhaust during deceleration. Best way to describe it was thunder. I had people ask me constantly how I was able to do that. Well, I didn't really know! I had the cats still on as well as the xpipe, but nothing else (no muffler/resonators).
I recently purchased a 2019 Challenger R/T, and was expecting the same results. I have taken off all mufflers and resonators, and left only the xpipe. When I drive in the sport mode or shiftable automatic, I am getting nothing close to the same sound. It only makes a fluttering/flapping sound while it is decelerating. Has anyone out there found a way to get that rumble with the Challenger? I understand how the rumble sound is made due to gasses still lingering after letting off the pedal, but I just cant seem to replicate the same thunderous sound I once had :frown:
Hello all,
one of the contributing factors is your Magnum engine didn't have VVT as any '09+ 5.7 engine has. The VVT changes based on engine load and deceleration as well.
The 2019 has active exhaust and that system often is louder than the 392 engine
Reactions: nwooz1990
2016 SRT
Also 5 speed vs 8 speed autos with the gears farther apart.
I have SPS a8 and I luv the pops and burbles on the deceleration. I drive my car in manual mode too. My car also has race bullets in place of mufflers. Maybe that's why.
Hello all,
I recently purchased a 2019 Challenger R/T, and was expecting the same results. I have taken off all mufflers and resonators, and left only the xpipe. When I drive in the sport mode or shiftable automatic, I am getting nothing close to the same sound. It only makes a fluttering/flapping sound while it is decelerating. Has anyone out there found a way to get that rumble with the Challenger? I understand how the rumble sound is made due to gasses still lingering after letting off the pedal, but I just cant seem to replicate the same thunderous sound I once had /forums/images/ChallengerTalk_2014/smilies/tango_face_sad.png
I could have sworn the Magnum had the VVT, that’s why I drove in manual mode constantly because it sounded terrible going from 4-8 cylinders.
2016 SRT
Wouldn’t driving in manual in 1-3rd gear be pretty close whether it was 5 or 8 speed?
Still a bigger drop on downshift with the 5 speed. I can get a nice rumble with a twitch of the toe on the gas.
VVT is Variable Valve Timing, not MDS (Multiple Displacement System) which disables 4 cylinders
Same here, Since i have had the Dynomax Bullets in i get much more crackles and pops then was stock on the SP that is. Very similar to the Camaro 2SS i had with deleted 2nd cats.
The difference is definitely not the vvt versus not. I have a built 13’ Challenger and just bought a 06’ Charger Daytona. Challenger is by far way louder but both give that loud de acceleration when coming to a stop. I never drive the Challenger in auto stick either so I wouldn’t put it on that.
My guess, as others have said, would be the transmission change from the 5 spd to 8. More gears it has to drop through. So instead of a long de acceleration and amazing sound, you get a sort of fluttering as it drops a number of gears spaced apart differently than what you may be used to.
If you want decel pop you could adjust the tune so DFCO is disabled and let min timing be around -20ish degrees. That being said, on my RT M6, when I deleted the mid mufflers from the corsa exhaust it had a very health brrraaahhhhh when decelerating.
Replaced the mid mufflers with Dynomax mini race bullets on SP M6. Much deeper growl and cracks and pops downshifting and decelerating.
Sent from my SM-T810 using Tapatalk
Discussion Starter #13
Thanks for all the responses. Might check out some tune routes.
1 - 13 of 13 Posts
