1 - 12 of 12 Posts
DEMON PERFORMANCE FRONT BRAKE ROTOR SET 2015-2017 SRT/SRT HELLCAT CHALLENGER/CHARGER
The Demon Performance HellCat brake system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The front rotors are 24.4 lbs vs. 31 lbs for the stock HC 2 piece units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of these rotors are made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from Demon Performance's own proprietary cast iron, poured in the USA and machined from start to finish for these specifically. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 12 high strength alloy steel drive pins, manufactured in the USA to Demon Performance's own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self-center between the pads.
Once the Demon Performance brake system is in place, simply replace the rotor rings when needed.
To Order Front Rotor (pair): Demon Performance Front Brake Rotor Set 2015-2017 SRT/SRT Hellcat Challenger/Charger
To Order Front Rotor Ring (pair): Demon Performance Front Brake Rotor Replacement Rings 2015-2017 SRT/SRT Hellcat Challenger/Charger
DEMON PERFORMANCE REAR BRAKE ROTOR SET 2005-2017 6.1L/392/6.4L/6.2L CHALLENGER/CHARGER/300/MAGNUM
The Demon Performance brake system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The rear rotors are 18.9 lbs vs. 24 lbs for the stock units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
To Order Rear Rotor (pair): Demon Performance Rear Brake Rotor Set 2005-2017 6.1L/392/6.4L/6.2L Challenger/Charger/300/Magnum
To Order Rear Rotor Rings (pair): Demon Performance Rear Brake Rotor Replacement Rings 2005-2017 6.1L/392/6.4L/6.2L Challenger/Charger/300/Magnum
DEMON PERFORMANCE STREET BRAKE PADS
Street Pads are the solution to your squeaky, dusty, expensive factory pads. They have less dust than typical factory pads and much less than typical performance pads. You won't be cleaning your wheels nearly as often. Additionally, they have great initial bite, something most less expensive pads are lacking. But the real reason people like Demon Performance pads so much is they are the "silver bullet" to brake noise problems. Street pads are a semi-metallic composition that is easy on the rotors and the wallet. Demon Performance recommends always replacing pads as a whole car set when switching compounds. All street pads come with their anti-noise shields pre-installed, included in the price. When comparison shopping, be sure to notice the quality of the components.
To Order:
Front: Demon Performance Street Front Brake Pads 2015-2017 SRT/SRT Hellcat Challenger/Charger
Rear: Demon Performance Street Rear Brake Pads 2005-2017 6.1L/392/6.4L/6.2L Challenger/Charger/300/Magnum
DEMON PERFORMANCE S/S RACING PADS
Brand new intermediate pad called the S/S pads for street/strip. These pads feature a hotter compound than Demon Performance's standard Street pads and are capable of maintaining braking efficiency up to 1000 degrees. Inevitably these will dust a little more than their Street pads and can make a little noise from time to time however with their anti noise backing plates - which all pads will come with - they have heard very little to no noise from these pads.
Comparatively the S/S pads perform very similarly to the Ferodo DS2500's, a pad which Demon Performance has had very good luck with in the past.
To Order:
Front: Demon Performance S/S Racing Front Brake Pads 2015-2017 SRT/SRT Hellcat Challenger/Charger
Rear: Demon Performance S/S Racing Rear Brake Pads 2005-2017 6.1L/392/6.4L/6.2L Challenger/Charger/300/Magnum
Thanks
Chris
I am going to have to get a set of these!
1 - 12 of 12 Posts
