1 - 1 of 1 Posts
DIABLOSPORT REAPER STAGE 1 CAI/TUNER KIT
The DiabloSport Reaper Stage 1 Kit is a performance combo that is designed to improve power, drivability, and mileage potential. Pairing tuning that is designed to account for increased airflow, from a high efficiency intake, is the best way to build power on late model gas vehicles. Reaper Stage 1 Kits take the guesswork out of trying to pair performance products from multiple companies by adding all the components in one high performance package. Now you can take your ride to the next level with the Reaper Stage 1 Kit from DiabloSport.
  • Add Horsepower, Torque and Fuel Economy to your vehicle without even popping the hood!
  • Featuring the latest generation ARM processor. The device's display has a higher resolution screen and an exceptionally responsive touch pad.
  • DiabloSport's pre-loaded tunes are dyno and street tested to ensure optimal power and drivability gains. Basic installation, big power gains!
  • Easy tune asks you for what octane gas you want to run, if you've changed your tire size, if you want to remove the speed limiter and more. It's the perfect way to drop a tune on your ride in minutes!
  • Start off with DiabloSport's preset performance tunes and make changes that suit your performance needs. Adjust options like timing, fueling, idle, speed limiters, rev limiters, tire size, gear ratios and more.
  • The i3 retrieves diagnostic data of how your vehicle's tune is performing. Export all of your data to a PC and play it back on DiabloSport's Data Viewer logging software.
  • Regardless of whether you purchased an i3 for a Chrysler, Ford, or GM- you can buy an additional license to tune ANY vehicle supported by DiabloSport!
  • Update your i3 software on virtually any computer- Mac, Windows, Linux. Update times are faster than ever, even large updates only take about 5 minutes.
  • Holds up to 5 custom tunes. Use our worldwide network of CMR tuners to step above our canned tunes.
  • 93 Octane Performance Tune: 15HP 20TQ
  • 91 Octane Performance Tune: 13HP 15TQ
  • Touch Screen
  • Data Logging
  • Check Clear DTCs
  • 5 Volt Data Logging Inputs
  • Accepts Custom Tunes from CMR
  • Calibrate Speedometer for Gear Ratio
  • Calibrate Speedo for Tire Size
  • Cooling Fan Control
  • Disable ESP
  • Throttle Booster
  • Fuel Rich/Lean Adjustment
  • Spark Timing Advance/Retard
  • Idle RPM
  • Top Speed Limiter
  • Rev Limiter
  • Torque Management Adjustment
  • Disable Active Fuel Management
  • Reset TCM Adaptation
  • Disable Skip Shift
To Order:
2011-2014 - DiabloSport Reaper Stage 1 CAI/Tuner Kit 2011-2014 392/6.4L Challenger/Charger
2012-2017 - DiabloSport Reaper Stage 1 CAI/Tuner Kit 2015-2017 392/6.4L Challenger/Charger
Thanks
Chris
1 - 1 of 1 Posts
