1 - 3 of 3 Posts
Anyone change their fluid yet? Is there a drain plug....or do you have to remove the cover? Haven't looked yet.
There's a drain plug on the bottom of the Getrag 226 housing - the differential lube requires the friction modified hypoid oil (due to the Sure Grip limited slip).
On the side of the housing, you'll find the filler plug.
OK cool! seems similar to C5 Vette.
Thought i saw someone post that you have to remove diff cover!
1 - 3 of 3 Posts
