1 - 12 of 12 Posts
I have a 2010 r/t automatic, and I can't believe mopar would put a open dif in a performance car. Anyone know of a lsd brand that can easily swap and a good price. thanks
Just get a stock 09 or up SRT automatic differential they are LSD but you need the axles also...hubs are the same
09 RT Challenger auto
Wave Trac is the way to go. I think GSO is using this with the stock 09 axels. If I didnt find a deal on a LSD with 3:06 gearing and 1000hp shafts. I would have definetly went wave trac. They run about 8 to 9 hundred for ours. For a stang same unit runs 5 to 6 hundred, go figure.
We installed a wave trac in a cobra friday, went in great, works even better.
FT
Yes it is an "open" rear, but depending what you plan on doing with your car, it works ok. I have the same "open" rear and I bolt slicks on and smoke em' both at the track. The car hooks well! :smokin:
1 - 12 of 12 Posts
