2018 Challenger Scat Pack Blacktop Package 6MT
Yo!
About 32k miles and several race, drift and track days my differential is finally showing signs of having too much fun.
The Diff will Hum during turns, u-turns, turning tightly in a parking lot.
I don't think my differential is damaged but has some fluid issues. Any recommendations on what friction modifiers to use with a fresh fluid flush?
If you really think it's not the fluid, I welcome suggestions to what is worn out.
try changing out the diff lube - and add more friction modifier to see if that helps.
you may have a lot of clutch friction material in that old lube and it makes the clutches drag.
otherwise, if that doesn't help - it could be bearing wear. The noise only during tight turns makes me think the clutches are grabbing too much
Reactions: Maxoom
awesome, thank you brother
I will try the lube and see if it solves my problem. I have fair confidence it will be all good, I did forget to mention I'm a 6MT so it's not the Auto Diff, I think they're different.
That being said, I just wanted to make sure that I could throw any friction modifier like ones made by "Lucas" or is it smart to stick to Mopars LT### Friction Modifier?
I've used the brands that were sold in the auto parts stores. They are designed for the same function - allow the clutches to slip so that they aren't engaging constantly and wearing out more quickly
2016 R/T Scat Pack
Had my diff fluid changed and a friction modifier added under warranty a few weeks ago. 2016 SP with 16k miles. The noise when turning is gone.
I used redline, it meets MOPAR specs, and comes with the friction modifier
I had my differential fluid replaced by a shop near me around 100,000 miles...they also used Redline with friction modifier..
