1 - 14 of 14 Posts
I have a 2013 challenger rt, how can I find out what type and quantity does my differential need?.
want to find out, what type of rear axle differential my car as, if its a standard or limited slip etc....I know I need 75w-90 I buy only amsoil products.
Which one does it look like?
#1 or #2?
So that's a Getrag limited slip, the 75W-90 is good (need 2 quarts) and will also need a bottle of the Mopar limited slip additive.
Don't you just full a differential up to the fill hole? I know on old cars if you remove the fill plug and can stick your pinky in the hole and touch fluid it is good.
This^
Put one bottle in, then the limited slip fluid, then start the next bottle. Probably will only get about 2/3 to 3/4 of the second bottle in. Fill till it trickles out the fill hole and wait till it stops before sealing it up. Make sure the car is level when doing this.
Doesn't Mopar make the the differential fluid with the friction modifier already added?
Yes but it's high dollar and some say they still had to use the additive so it's a tossup. Last time I used Royal Purple with half bottle of TransX and works great.
1 - 14 of 14 Posts
