1 - 11 of 11 Posts
2017 T/A 5.7 A8 front and rear strut braces frame connectors
The only reason I ask is because I got a 2009 mustang new so when I went to do my first oil change I got a brand new grease gun and there was not one grease fitting on the car
No - these models do not have grease (zerk) fittings - its been pretty common for 20 - 25 years that suspension parts have "sealed" joints. If the boot tears or the joint has play - its replaced.
another thing you'll notice as well are "sealed" wheel bearings - no more front wheel bearings are packed or adjusted. The entire bearing unit gets replaced if its wearing / excess clearance, end play
Thanks Hal H you saved the hassle of crawling around under the car even though it would make me feel better knowing that the car was greased.even that I’m getting up there in age I still wanna work on my car.somehow I still enjoy the only thing you can do is bolt on parts.i had a new pick up and came out of the grocery store jumped into the truck and it would turn over no start.got out popped the hood realized there’s nothing I could do grabbed my phone and called a tow truck.thats when I realized that the days of wiggling wires were long gone
Wanting to grease the fittings is like wanting to defrag your drive...but it's a SSD...habit ;)
Grease fittings, welcome to the 70's.
I had grease fittings on my 02 Silverado. Not sure when they stopped on cars though.
My 01 Z28 had no grease fittings. Not sure about now but the 05 Silverado still had them, there's 11 on the front end if 4WD.
When I bought my Mustang GT 5.0 back in 1984, my first new car I changed my oil and when I went to grease all the front steering parts I found there were no zerks on anything.
Today the only zerk fittings I have are on my commercial grade lawn equipment.
It’s a way different time but if you replace parts with Moog brand ones they still have that option.
When u rebuilt my front end, i went with moog problem solver components. Buying their upgraded line whenever possible. They ad zerk fittings for the lower ball joint, and the toe arms.
I also use a needle fitting to inject the upper ball joint with grease, and use silicone to seal the hole
Going on 40k miles with the moog parts (5k on the tow arms)
So when time comes to replace , you can look into options that have zerk fittings
Saves the 5 minute hassle of greasing fittings when the oil is changed and then you can replace all the components in a few years!
My front suspension been making noises...I wish I could blame it on "un-greased fittings"....ughhh....
1 - 11 of 11 Posts
