1 - 1 of 1 Posts
D
Guest
Located in New Rochelle, New York
Dodge : Challenger NA XV '70 Dodge Challenger Supercar!
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
XV001, XV Motorsports first production car, is available for sale. Click below to check out all the details on this amazing XV Challenger!: * * Designed, engineered and built from the ground up to strike terror into the hearts of contemporary luxury exotic owners, on the street or on the track. XV Motorsports has taken the concept of the modern musclecar to a level never before attained using OE and professional motorsports technologies unheard of in the performance aftermarket. Nothing else even comes close. 1970 DODGE CHALLENGER - XV001 Here is a YouTube link to XV001 being run around a road course: https://www.youtube.com/watch?v=x7FnInueXR4 * ENGINE, FUEL AND EXHAUST - XV 440 HP 5.7 HEMI Engine Package XV Custom Tuned Electonic Engine Management System Electronic Fuel Injection Distributorless Ignition Closed Loop Tuning with Oxygen Sensors Performance Camshaft Extended RPM Valvespring Package XV Main Stud Kit XV Head Stud Kit XV Aluminum Oil Pan XV Hand Assembly of Engine (Balanced and Blueprinted) XV Custom Aluminum Radiator and Shroud Package w/ Electric Fans XV Level II Exhaust Package XV Equal Length Stainless Steel Exhaust Headers XV 3" Stainless Steel Dual Exhaust with H-Pipe and Polished Tips XV EFI Fuel System XV Custom EFI Fuel Tank Stainless Steel Feed and Return Hard Lines Braided Stainless Engine Compartment Fuel Lines w/ AN Fittings Adjustable Pressure Regulator High Flow EFI Fuel Filter TRANSMISSION AND DRIVELINE - XV 5-Speed Package Tremec TKO 5-Speed Manual Transmission Heavy Duty Clutch Hydraulic Throwout Bearing XV Heavy Duty 8-3/4" Rear End Assmbly High strength nodular iron center section with billet adjusters True-Trac Limited Slip Differential (Torsen Style Differential) 3.91 performance axle ratio Alloy axles with heavy duty bearings 3" Alloy wheel studs Synthetic differential lube SUSPENSION - XV Level II Suspension Package Front Supension XV SLA Double A-Arms (aluminum upper and lower A-Arms) XV Aluminum Spindles XV Aluminum K-Member XV Adjustable Coilover Shock Absorbers, custom valved, aluminum body XV Custom Front Anti-Roll Bar XV Variable Rate Power Steering Rack XV Adjustable Bump Steer Kit Rear Suspension XV Three Link Rear Suspension Billet Aluminum Lower Links Adjustable Upper Link XV Adjustable Panhard Bar Assembly XV Adjustable Coilover Shock Absorbers, custom valved, aluminum body XV Custom Rear Anti-Roll Bar XV Chassis Stiffening System XV Engine Compartment Brace XV Laser Cut Subframe Connectors XV Lower Rad Support / Frame Rail Connector XV Inner Fender Shock Tower Brace BRAKES - XV Level II Brake Package 6 Piston Front Caliper w/ 14" Rotors 2 Piston Rear Caliper w/ 13" Rotors Two piece, vented slotted rotors w/ billet hats Hydroboost power brake booster Stainless steel hardlines Braided stainless brake hoses High performance brake pad package High temp brake fluid WHEELS AND TIRES - Kinesis 5 Spoke Polished Black Anodized Wheels E-Body Front 18" X 9.5" Rear 18" X 10" Ultra High Performance Wet or Dry Tires E-Body Front 275/35-18 Rear 295/35-18 Tires are Y rated to 186 MPH INTERIOR - XV Seating XV Custom Leather Upholstered Seats, Custom Leather Upholstered Rear Seat XV Custom Carpeting, XV Custom Dash Pad with Logo XV Tilt Column XV Custom leather wrapped billet steering wheel with logo XV Custom Instrument Cluster XV Custom 200 MPH Speedo XV Custom 10,000 RPM Tachometer XV Custom Water Temp, Oil Pressure, Fuel Level and Volt Gauges NOTE: Instruments are silver face, with blue LED backlighting Leather wrapped door panels, console, dash pad, rear side panels, pillars and kick panels Dynamat Sound Deadener Throughout interior Interior Color: BLACK Entertainment Alpine Head Unit i-Pod Interface Alpine Speakers front and rear Alpine Subwoofers Alpine Amplifiers Power Antenna Heavy Duty Wiring Climate Control Air Conditioning Heat Front Window Defroster XV Fully Finished Carpeted Trunk XV Convenience Package Power Door Locks Power Windows Keyless Entry Alarm System Remote Trunk Release EXTERIOR - Functional T/A Hood w/ Air Cleaner T/A Decklid Spoiler Paint Show Quality Paint Job Exterior Color: XV Orange
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
