that might be the exterior temp sensor - its clipped to the backside of the front grille
Reactions: FromtheLotus7
it probably pulled out of the connector that is still attached to the temp sensor.
This is the part (ambient temp sensor) its a two wire weather pak connector that you pulled the wires out of. The connector is probably gray or white plastic that is still clipped on the sensor.
Its on the left or right side (whatever side the wire is on) clipped behind the grill area.
Two wires eh? That means I have to pull everything apart and get to the original sensor. Damn!
probably remove the top trim panels and look around in there to locate the sensor. You might not have to take everything that far apart.
So it wasn't the sensor. That was fully intact. it was actually for the horn on the driver's side.
But thank you for the assistance. I'll post some pics of the halo's and Phantom grill in a few hours.
