2016 SRT
Hello all. How hard/difficult is it to remove passenger door panel? The reason I ask is I hit something on the highway at night and the object bounched up and hit dead center of door but very low, so I was thinking of popping the dent back out and use some touch up paint. The dent is smaller then a finger nail. Just can't see spending 400-600 bucks for body shop to repair. I'm sick to my stomach that this even happened but happens I guess. Thanks
Mopar or No Car
2019 Sublime Shaker and 2010 Detonator Yellow R/T Classic
Mopar or No Car
Not hard at all, just take your time, the door (for the 1st time you remove it) will not want to release it's retainers. There are 3 screws under the bottom of the door that have to be removed and 2 screws that are behind little panels, 1 on the door pull-top and 1 behind the inner door handle that have to be removed. There is another small black plastic retainer that pops out to near the bottom edge door hinge area that also has to come out. The door will also have some disconnects for the electrical items once you remove it and the inner door cable release as well. I have removed dozens of these doors. There are videos out there on YouTube.
Good info from Hunttriumph1500. In addition, here is a link-back to one of threads here on the forum that I used when replacing the speakers in my 2016. It shows how to remove the door panels step by step complete with photos.
Very easy. Some screws and push pins is all there is. The only tricky part is getting the door handle rod back in to it's clip upon reassembly. Helps A LOT to have someone help you hold the panel while you clip it back in. I did it by myself, but had to balance the panel on a cardboard box to do it. Good luck. ;)
I’m a professional body man, with some experience in PDR (paintless dent repair) as well. If the dent is as small as you say, chances are good the metal is slightly stretched, and won’t just pop back out. A PDR guy could massage it back out and then you could use touch up paint. I doubt for a single dent a good PDR guy would charge more than $50.
