1 - 2 of 2 Posts
I wanted to get some reccomendations and maybe aquote from Discount tire. I am looking at drag radials and rims, in an 18 inch size. It is difficult to find 18 inch rims that are wide enough for a drag radial, have the 115 mm pattern and still remain inexpensive. The two rims I have come up with are:
ION Alloy 18x9 5x115mm
Display Custom Wheel Fitment
and the Nascar 614 which is 18x8.5 115mm pattern:
nascar 614 rims and tires packages. nascar 614 black w/ stripe wheels and tires packages at WheelsNext.com
Tires I am looking at are the MH Racemaster drag radial 275/45R18 and the MT ET Street radial P265/40R18
For the fronts I will run stock 18x4 Challenger spare rims with MH front runners 185/50R18 which will double as spare tires when I am not racing.
Basically looking for one quote for all four tires and rear rims, I have one spare rim for the front and will buy another from my Dodge dealer. Also looking for advice on whether or not these rims are in fact 115mm and if I can run them on a 8.5 or 9 inch wide rim. Tire manufacturers reccommend 9-10 inch rims for both.
Supporting Vendor
Tire & Wheel Specialists
Both of these wheels are designed and built for trucks. With that said they may be able to work for you but you would really need to test fit them. I would recommend contacting a local retailer. If you have a Discount Tire or America's tire in your area stop in and tell them what you are trying to do. They may be able to help you test fit a couple options. They can work up a few price quotes and they may have some additional options for you to consider as well.
1 - 2 of 2 Posts
