Hey guys, I traded my 12 R/T Classic 6-speed for a 16 SRT 6-speed. Now, when I drive my SRT and step on the gas, even just driving normally, I get a whirring sound from the rear end. My R/T with stp did not do this. Honestly, the SRT sounds a lot like the Dana 60 with 4.10s in my 69 Charger. Is this normal for the SRTs?
hey guys i traded my 12 rt classic 6 speed for a 16 srt 6 speed. now when i drive my srt and step on the gas even just driving normally i get like a while or a whirring what soulds like the rear end. my rt with stp did not do this. honestly the srt sounds alot like the dana 60 with 4.10s in my 69 charger. is this normal for the srt's?
There was a service campaign on some '16s that the dealer would inspect to check the parts tag (for production dates) on the driveshaft for some that would make whirring sounds
Models - 2015-2016 Challenger/Charger/300
Month/Day/Hour - built before October 15, 2015 (Challenger) or March 28, 2016 (Charger)
Noise - New TSB 6/24/16: Inspecting and replacing the propeller shaft due to a whining noise at high speeds
Part - current driveshaft part is 53010678AF and will be replaced with 53010
I remembered that I had posted this a while back:
http://www.challengertalk.com/forums/f188/rear-end-noise-512737/#post6822745
great info! whats the easiest way i can tell if my car is within the build dates?
Hmmmm, Yeah mine does this too. It's a 2015 Scat built around April, 2015. Is there any info that indicates that this is a condition that gets progressively worse, leading to driveshaft failure? I'll print the bulletin and contact my dealer. Thanks Hal.
Very easy - your sticker on your door will have the build date: MM:DD:HH and in another area MM/YY
I was fortunate - build 10/23 for mine; only needed the flash update for heated steering wheel [would shut off after 20 seconds after being turned on]
Mine was doing this in turns. It progressed to popping, especially during reverse turns it was very apparent then. My differential had to be replaced.
Haha i dint think it would be that easy! it gives that whirring noise while im on the gas. if i letoff it goes away. its very obvious around 40-45mph.
my door sticker says 12/15
