thank you! I believe I’m going to contact dodge next week and get it checked out, about 7-8 months ago they had to fix the door actuator because the smart window feature malfunctioned. That was a nightmare
Well, I hope I'm wrong but the nightmare might not be over. If the window adjustment was botched during the previous work on the window the odds of it being put right this time are down some.
But like I said I hope I'm wrong.
Trying to think of a way to "test" the window alignment without having to live with a possible bad alignment for months before the rubber seal starts to show the effects.
Since you have one window that appears to be properly adjusted maybe using a sheet of newspaper in the window and ensuring when the glass comes up it doesn't grab/tear the paper, but after the window is closed the effort to pull the paper out is not too much.
Rather than use the entire sheet try strips of newspaper. Printer paper may be too slick/slippery and strong. (But try strips of printer paper just to be sure.)
What you want try to be able to do is judge the amount of force it takes to pull the strip of paper out from between the window glass and the rubber seal.
You have the other window to do this to in order to establish a base line. Then before you take the car in try this on the bad window to establish what is not acceptable.
After you have had the car in have some strips of paper with you and "test" the problem window and see it the strips pull out like they do from the other side.
You might also ask the tech how he tests the adjustment. Maybe he has another way? (Chalk powder maybe?)
