2016 Scat Pack
My driver's side window has developed a really annoying, loud squeak when it does the auto drop and close.
I've tried cleaning the rubber at the top of the door, rubbing it with various cleaners, waxes, etc and nothing will stop it.
The passenger side is perfectly quiet. The car is a '16 SP and garage kept with 8,00 miles on it.
Anyone have any experience with this or any recommendation on what to apply to the rubber molding to do away with the squeak?
If it still squeaks with lube on the weather strip that may not be the source. Recheck it with the door open. You can manipulate the smart glass function by latching the door latch with a screw driver
2016 Scat Pack
You may want to use conditioner instead of lube. I've had good luck with Gummi Pfledge, used it on my Wrangler Unlimited and was pleased with the results. Kept the weather strips flexible/soft and the water out, easy to apply too.
https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG/ref=sr_1_1?s=automotive&ie=UTF8&qid=1504618696&sr=1-1&keywords=gummy+pflege
Thanks for this! I just ordered it from Amazon. Everything I read tells me it's something I should have already had.
