1 - 14 of 14 Posts
No, but my shop was thinking it was the rear link control arm , or there's no spacer added to the ds. I purchased the kit today (spacer) but having issues on finding the correct bushing for the arms.
Yeah I've got the exact same issue, I'm trying to find cradle spacers now. I have a DSS 4' 2 peace shaft. I'm actually trying to adjust the pinion with washers for now, so I can race this weekend. Hopefully it will work or else I'm stuck waiting on DSS to get back to me.
I have a 09 6speed car with a dss drive shaft
They sent spacers to go under the transmission support and a spacer to go between the rear end bushing mount and the frame
It is about a 1/2” thick and instructions states to use it it looked to close
Did you guys get these with your driveshaft ?
My car was built before I bought it, just finding small things that got overlooked, I called dss and they are sending me the kit. I will have my shop put it on.
I bought my shaft used (big mistake) so it didn’t come with the spacers. I’m going to order from DSS on Monday. For now I shimmed my pinion with heavy duty washers I have. With that said I’d rather have properly made spaces for the cradle.
The kit cost 25.00 w/shipping 40.00. I need to just get the carbon fiber one and be done with this.
2016 SRT Challenger Hellcat
Yes I had that issue.It was my Corsa exhaust. When I would power shift the rear end would go down hitting the exhaust. I had to put an elbow on both exhaust to keep it away from the drive shaft about 3 to 4 inch.Problem fixed.
Mine is rubbing the gas tank.?
Thanks for posting the price. I’m planning to purchase the kit tomorrow from DSS.
Dodge Challenger
Do you have pictures of the spacers? My shifter seems to be digging into my driveshaft wanna move it down a tad versus cutting the shifter
Dodge Challenger
Here’s a picture of the spacers Incase anyone wanted to see how’d they look like. You will need longer M10 1.5 bolts 90mm worked for me
1 - 14 of 14 Posts
