1 - 4 of 4 Posts
Only advice that can be given......make sure its strapped down nice and tight !:grin2:
I will be sure about the straps being tight.
Should I do a battery disconnect/reconnect to reset the factory defaults prior to the run?
What gear should the pull be made in?
Regular or sport mode?
Traction control on or off?
Anything else?
Whoever operates the dyno should know what is best for your model car. When I did mine (5.7 automatic) we went with sport mode ON (quicker shifts) and traction OFF. I also pulled the #2 fuse on the box to reset the adaptive learning. My dyno showed the actual HP at 375 HP as advertised. I just installed cutouts and will later add a Diablo tuner. Then I will dyno again to see what HP gain .....if any. My guy does 3 pulls for $100.
1 - 4 of 4 Posts
