Need to know exactly what to order along with the Eibach 2895.140. They're going on my 2016 Challenger SXT. Camber? Bushings? Whose cheap and reliable? Thanks.
Sent from my SM-N950U using Tapatalk
I highly recommend getting the Eibach pro dampers to go along with the springs.
Your stock SXT shocks are gong to be fairly soft valving and with lowering springs, they may not hold up that well.
Since you have to remove the front strut from the vehicle for the spring R & R, and check alignment afterward, you don't want to have to repeat that.
You may likely need upper control arms (front) with camber adjustment provisions. You'll probably end up on the high side of negative camber w/o them.
Similar for rear - bushings to allow adjustment.
The newer years have more negative camber stock, lowering the vehicle adds to the camber amount.
Thanks for the reply. Would you be so kind as to direct me to he proper part numbers? Thanks.
ProSystem (Pro Springs & dampers) #28112.780 these are the Pro lines that are 1.4"/1.5" F / R drop
SportSystem (Sport Springs & dampers #4.11028.780 these are the Sport Line that are 1.9" /2.0" F / R drop
dampers (if you already bought the springs) 28110.840
-its generally a cheaper deal to buy the spring & shock kits together vs. buying seperately.
Eibach also makes:
Caster/ camber arm kit - front camber +/- 2.0* caster, +/- 1.5* camber #5.66045K
Bushing kit 5.66050K - camber bushing kit
