1 - 2 of 2 Posts
I installed 2 inch eibach springs, and installed front sway strut bar, my ride is stiff the way i want them except now my suspension is not supporting the almost 4300lb 2015 Challenger R/T my car sits approx 4 inches of the ground. it bottoms out when i hit dips in the road.
How do i raise my springs up 1 inch? without ordering new springs? and will that fix my problem? I have the original springs i am tempted to go back to them in fear of damaging my suspension and spending more down the road.
sky jacker or other lift kit I suppose. If you know someone who is a machinist maybe they can make you an aluminum spacer or something to install between a coil on each corner of the car. Good Luck.... On the bright side, you can sell those to offset the cost of an adjustable set up.
1 - 2 of 2 Posts
