Ohio-Speed is having a sale on all Eibach Suspension Components with FREE S/H!
We are adding parts daily and if you don't see it listed we can still get it for you.
Our advertised price is not necessarily our lowest!
Join the winning teams around the world and switch to the Eibach performance advantage. Whether it's Formula 1, WRC or NASCAR, the winning factor is often chassis setup and tuning. When most teams have comparable power, the car that wins is the one with the most grip and puts maximum power to the ground—and maintain their momentum through the corners. Find the right Eibach suspension components for your car—today!
2008 2010 Dodge Challenger Eibach Multi-Pro-R2 Coil-Over Kit 2895-713 (shown)
2008 2010 Dodge Challenger Eibach Pro-Street-S Coil-Over Kit 2895-711
2008 2010 Dodge Challenger Eibach Multi-Pro-R1 Coil-Over Kit 2895-712
2008 2010 Dodge Challenger Eibach Pro-Dampers 2873-840
2008 2013 Dodge Challenger Eibach Pro-Kit Lowering Springs 2895-140
2008 2010 Dodge Challenger Eibach Sportline Lowering Springs 4-9528
2011 2012 Dodge Challenger Eibach Sportline Lowering Springs 28111140
2008 2010 Dodge Challenger Eibach Front 35mm Sway Bar 2895-310
2008 2010 Dodge Challenger Eibach Rear 19mm Sway Bar 2895-312
2008 2012 Dodge Challenger Eibach Front 35mm-Rear 19mm Sway Bars 2895-320
2008 2013 Dodge Challenger Eibach Pro-Plus Performance Handling Package 2895-880
2008 2010 Dodge Challenger Eibach Pro-System Suspension Lowering Kit 2895-780
2008 2010 Dodge Challenger Eibach Sport-System Suspension Lowering Kit 4-9528-780
2008 2011 Dodge Challenger Eibach Sport-System-Plus Suspension Lowering Kit 4-9528-680
2008 2010 Dodge Challenger Eibach Pro-System-Plus Suspension Lowering Kit 2895-680
2008 2010 Dodge Challenger Eibach Alignment Kit 5-66085K
2008 2010 Dodge Challenger Eibach Alignment Kits 5-66080K
Dodge Challenger Eibach Alignment Kits 5-66030K
PM FOR OUR LOW PRICES WITH FREE S/H!
These Eibach Multi-Pro-R2 coil-over kits are specially tuned to extract the maximum cornering power from your vehicle. They allow you to precisely tune the corner weights for optimum handling balance, and the wide range of damping adjustability lets you tune for comfort or grip. The Eibach Multi-Pro-R2 coil-over kits can be adjusted for independent rebound and compression damping with the included remote mount reservoirs. They use 46mm piston monotube dampers, spherical upper bushing mounts, and braided stainless steel reservoir lines.
Suspension Height Adjustment:0.0-2.3 in. lowered front, 0.0-1.8 in. lowered rear
Coil-Over Kit Position:Front and rear
Shocks Included:Yes
Adjustable Valving:No
Internal Design:Monotube
Gas Charged:Yes
Number of Valving Selections:Infinite
Shock Body Material:Stainless steel
Shock Body Finish:Natural
Coil-Over Springs Included:Yes
Spring Finish:Red powdercoated
Crossmember Included:No
Adjustable Mounting Bracket Included:No
Hardware Included:Yes
Welding Required:No
Quantity:Sold as a kit.
Notes:Remote reservoirs and stainless steel Teflon® braided lines included
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:R/T
Beginning Year:2009
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:SRT8
Beginning Year:2008
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
PM FOR OUR LOW PRICE WITH FREE S/H!
Discussion Starter #2 (Edited)
PM FOR OUR BEST PRICE AVAILABLE!
Eibach Pro-Street-S coil-over kits use the very same Eibach technology used in the latest Formula 1 car. Now, you can get each corner of your vehicle looking and performing its very best. Eibach's exciting new Pro-Street-S stainless steel bodied coil-over spring/damper packages let serious drivers quickly adjust the ride height of each individual wheel. Eibach ERS racing springs and ERD racing dampers are used in top-level racing series all over the world. Eibach has used this experience, gained from many decades at the highest levels of international motorsports, including Formula 1, NASCAR, CART, IRL, Super Car Touring, and the World Rally Championship, to put these technological masterpieces into the hands of performance enthusiasts everywhere.
Eibach Pro-Street-S coil-over kits feature:
* High performance Eibach tuned coil-overs
* The next level of suspension technology
* Quick-adjustable lowering from 0.8 in. to 3.0 in.
* Optimal tuning for aggressive performance
* Rust-free stainless steel technology
* Legendary Eibach suspension quality and tuning
Suspension Height Adjustment:0.0-2.5 in. lowered front, 0.0-2.0 in. lowered rear
Shocks Included:Yes
Gas Charged:Yes
Welding Required:No
Quantity:Sold as a set of 4.
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:R/T
Beginning Year:2009
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:SRT8
Beginning Year:2008
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
These Eibach Multi-Pro-R1 coil-over kits feature state-of-the art, race-ready, dampening adjustable coil-overs with a 46mm piston monotube design for maximum street and track performance.
The ride height is infinitely adjustable and the dual spring setup is dialed-in for maximum cornering.
Rebound and compression damping are both adjusted, ensuring proper damping balance at any setting.
Eibach Multi-Pro-R1 coil-over kits have stainless steel damper bodies for extreme durability and corrosion protection.
Shocks Included:Yes
Adjustable Valving:Yes
Gas Charged:Yes
Welding Required:No
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:R/T
Beginning Year:2009
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
Universal:No
Make: DODGE
Model:CHALLENGER
Submodel:SRT8
Beginning Year:2008
Ending Year:2010
Engine Type:V8
Drivetrain:RWD
Eibach developed Pro-Dampers specifically to complement the unique characteristics of Eibach Pro-Kit and Sportline springs, taking full advantage of the increased spring rate and lower center of gravity.
The result is enhanced performance throughout the entire working range of the suspension.
Eibach engineers tuned Pro-Damper damping characteristics to achieve maximum performance, but without excessive stiffness or ride harshness.
This precise tuning takes time and suspension expertise--a commitment that Eibach undertakes to produce dampers worthy of the Eibach name.
Shock Mount Type:Standard
Shock Quantity Per Mount:1
Internal Design:Twin-tube
Gas Charged:No
Adjustable:No
Notes:Will not fit AWD models.
These Pro-Kit lowering springs are Eibach's most popular springs--and there's a reason for that.
These springs reduce fender gap to give your vehicle a lower, more aggressive stance.
Plus, Eibach Pro-Kit lowering springs help to lower the center of gravity to improve handling during acceleration, cornering, and braking.
Best of all, you can lower your vehicle without having to change your shocks.
Spring Position:Front and rear
Spring Type:Coil
Progressive Rate Spring:Yes
Bushings Included:No
Spring Finish:Black powdercoated
Notes:Vehicles equipped with load leveling rear suspension (Nivomat) must install kit EIB-2873-840 for correct lowering.
Make: DODGE
Model:CHALLENGER
Submodel:R/T
Beginning Year:2009
Ending Year:2013
Engine Type:V8
Liter:5.7
CID:345
Engine Size:5.7L/345
Engine Family:Mopar Hemi V8 Modular
Amount of Drop Front:1.700 in.
Amount of Drop Rear:1.700 in.
Drivetrain:RWD
Make: DODGE
Model:CHALLENGER
Submodel:R/T CLASSIC
Beginning Year:2012
Ending Year:2012
Engine Type:V8
Liter:5.7
CID:345
Drivetrain:RWD
Make: DODGE
Model:CHALLENGER
Submodel:SRT8
Beginning Year:2008
Ending Year:2010
Engine Type:V8
Liter:6.1
CID:370
Engine Size:6.1L/370
Amount of Drop Front:0.800 in.
Amount of Drop Rear:0.800 in.
Drivetrain:RWD
Are you looking for the lowest possible street ride?
These Eibach Sportline springs slam your vehicle anywhere from 1 3/4 in. to 2 1/4 in.
That not only gives your ride that race car look, but it also dramatically improves your handling.
These Eibach Sportline lowering springs provide the ultimate balance between high performance, extreme lowering, and comfortable ride quality
Spring Type:Coil
Make: DODGE
Model:CHALLENGER
Submodel:R/T
Beginning Year:2009
Ending Year:2010
Engine Type:V8
Liter:5.7
CID:345
Amount of Drop Front:2.000 in.
Amount of Drop Rear:2.100 in.
Drivetrain:RWD
Make: DODGE
Model:CHALLENGER
Submodel:SE
Beginning Year:2009
Ending Year:2010
Engine Type:V6
Liter:3.5
CID:215
Engine Size:3.5L/215
Engine Family:Mopar V6
Amount of Drop Front:1.900 in.
Amount of Drop Rear:2.000 in.
Drivetrain:RWD
Make: DODGE
Model:CHALLENGER
Submodel:SRT8
Beginning Year:2008
Ending Year:2010
Engine Type:V8
Liter:6.1
CID:370
Amount of Drop Front:1.100 in.
Amount of Drop Rear:1.200 in.
Drivetrain:RWD
Eibach's anti-roll kits allow for the critical fine-tuning of your car's handling characteristics.
These kits reduce body roll through increased design stiffness over stock bars.
The results are increased handling and cornering grip in any performance-driving situation
Front Sway Bar Type:Hollow
Rear Sway Bar Type:Hollow
Front Sway Bar Diameter (in):1.375 in.
Front Sway Bar Diameter (mm):35.00mm
Rear Sway Bar Diameter (in):0.750 in.
Rear Sway Bar Diameter (mm):19.00mm
Mounting Hardware Included:Yes
Sway Bar Finish:Red powdercoated
Sway Bar Material:Steel
