“…Or have the car in and have a professional tech make the diagnosis….”
That’s the part that scares me…hard to find anyone that knows what they are doing these days.
Thanks for the info..
By the way…got oil change at dealer with the inspection…light still on…
Saw a video on replacing these…they always break when trying to get out…doesn’t sound real easy to me..but of course I have a hard time changing light bulb…
Stupid question…if it was “because needed oil change”…would/should light go off after oil change?..or does it manually need to be reset/turned off?
If by "light still on" you are referring to the CEL, if the error arose from the oil the CEL should go off but maybe not right away after an oil change. For some errors if the error condition is not present at engine start the CEL is turned off. For other errors the engine controller needs several warm up cycles with the error absent before it extinguishes the CEL. I would hazard a guess an error related to the MDS would require several warm up cycles with the error absent before the PCM would erase the code and extinguish the CEL.
With a proper OBD2 scan tool you can clear the error which should extinguish the CEL. If you restart the engine and the CEL comes on that is because the PCM detected the error at engine start. Or the CEL may come on after the engine (and solenoid) get up to temperature.
I mentioned the oil change because that has in some cases resulted in an error related to the MDS system.
But I agree with others that is more likely the solenoid.
No Dodge experience but a previous car developed a problem with the variable (intake) cam timing solenoid/actuator. I had no qualms about taking the car to my local dealer. 'course, I had had this car and another car serviced there, and some other issues addressed, and as a result of my experience I had 100% confidence the tech was quite capable of a proper repair. He was. He replaced both the solenoid and the actuator. This was an out of warranty repair and cost around $3K. But I put close to 100K miles on the engine after the repair with no problems arising from the repair.
Might mention in this case there was no way to determine if the solenoid or actuator was bad. So the factory called for both items to be replaced. As it turned out the solenoid failed but did so in such a way it "took" out the actuator.
As was the case with the above car and its problem, so too is it with your car. It is unlikely this work would be turned over to be done by anyone but a senior and experienced tech. The dealer warranties the parts and labor. Should a problem develop you have the warranty to fall back upon.
I'm no expert on MDS issues but reading other posts it appears this problem is not a benign one and if not addressed promptly can result in more serious problems maybe even take out the engine.
Whatever you decide to do you better decide ASAP.
