1 - 3 of 3 Posts
<U>Professionally Built by Arrington Racing
in MartinsvilleVa.
Orange 426 SC 2009 Challenger SRT-8
Car only has 1300 miles on it and 1000 on the whole set up. The car makes over 675 rwhp and over 750 rwtq all on pump gas. (Again this is to the rear wheels) The car make at least 20% or more at the motor, which should put the car well in the 750 hp or more and over 825 pounds of torque or more. Car has all options except for navigation and Sunroof. The car is in mint condition and still smells new. I have well over 50k invested into the car. The car will run easily 10's at over 130mph the way it sits on street tires.
426 HEMI Long Block
Performance Parts
  • <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>HEMI 6.1 Block <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>K-1 Pistons, Steel Rods, Steel Crank, Reluctor <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>Comp Cam Pushrods <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>Custom made Arrington Super Charger Camshaft <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>Other HEMI Performance Parts <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>ARP Bolt <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>Manley Double Roller Timing Chine <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>ATI Super Damper Harmonic Balancer for 6.1 Hemi <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l4 level1 lfo1; tab-stops: list .5in" class=MsoNormal>Fore Precision Works HEMI Billet Fuel Rails
  • American Racing Long Tube Headers
Precision Labor
  • <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo2; tab-stops: list .5in" class=MsoNormal>CNC Ported Cylinder Heads stage 5 <LI style="LINE-HEIGHT: normal; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo2; tab-stops: list .5in" class=MsoNormal>NASCAR-finished Block and Mains
  • Engine and Cylinder Head Assembly
Harp Bullet Super Charger
  • Bullet supercharger kit, TVS 2300 Supercharger, satin finish w/integral liquid to air intercooler 9 psi Custom heat exchanger with coolant pumps, reservoir, lines, Electric Water pump and hardware Properly sized fuel injectors Kenne Bell Boost-a-pump fuel pump voltage booster, 180 degree thermostat, Billet aluminum tensioner pulley assembly RDP high flow air intake with K&N filter
HEMI Performance Transmission NAG 1 (722.6) High Torque Blueprinted and Built By Southern Hot Rod
  • This is the HEMI Transmission you need if you are putting down a lot of power. In addition to lowering your ET, your HEMI will accelerate faster, hook up better, and drive smoother. It can power 1,000+ HP cars.
Hemi Torque Converter
  • This is the Hemi 2800 Stall Torque Converter you need if you are putting down a lot of power. It can power 1,000+ HP cars.
HEMI Unlimited HP Axle and Hub Assemblies
  • HEMI 1,400 Horsepower Axle Sets
SUSPENSION
· Bump steer Kit by Razors Edge
· Eibach Pro Street Kit Adjustable Coil Overs
· Matrix Sub frame Connector Braces by Razors Edge
· 4 point Rear Strut Tower Brace by Razors Edge
· Strut Bar / Strut Tower Bar By Richard Petty
· Hotchkis Sway Bars
</U>
Hey buddy... Not to burst your bubble, but it sounds to me like you are trying to get everything you put in the car back out of it... The bad thing about putting that kind of money in mods in a car is that you NEVER get it back... Nature of the beast... Trust me I am talking from experience... I took a 25K loss... I wish you the best though... and good luck with the sale
1 - 3 of 3 Posts
