1 - 11 of 11 Posts
One of my exhaust tips is slightly crooked, and I want to adjust it so that it is not.
I loosened the clamp for the tip and tried to move it, but it would not turn. I notice that the bottom of the clamp is spot-welded to the pipe coming from the resonator. Is the tip also spot-welded somewhere?
Thanks.
On my car the spot weld was only on the pipes. When I changed my system I loosened the clamps and tapped the tips with a rubber mallet and they came off leaving the clamps in place.
Mine weren't. Of course the 2010 being the fastest.....they started welding the tips on afterwards. Many out ran the tips upon sudden acceleration. Just sayin'. :werd:
Reactions: Yellow Jacket 2012
The spot weld you see should be of the exhaust tip, and not to the pipe.
I am certain the tip will free itself with some WD-40 or a gentle nudge.
The clamp is welded to the output of the resonator, not the tip. Loosen the clamps and tap the tip with a rubber mallet (easy does it) and it will pop loose.
Perfect, thanks! I just didn't want to break one.
Got a belly laugh out of this comment. Reminds me of when I once out dove my swim trunks...
2015 Scat Pack
There was a pretty substantial weld on mine. I used a dremel with a cutting wheel to cut the weld. Took about 5 minutes each and a few little cutting discs.
Reactions: Bookmaker
That did the trick. I used a tiny level, and now my tips are level front to back, side to side, and centered. Looks perfect!
Reactions: Danner
Nice to hear all is right in your world again. lol.
1 - 11 of 11 Posts
