1 - 2 of 2 Posts
2016 Jazz Blue A8 Scat
Can the factory projector headlamps be upgraded to factory HID on 2015 and newer cars?
I assume you mean OEM parts? It would be much cheaper to do aftermarket. Be aware, the actual housings are different between halogen and HID. You can certainly put HIDs in the halogen projector housings, but the beam pattern will not be exactly the same. You might also consider LED upgrades, some are adjustable for beam pattern:
https://www.amazon.com/GENSSI-Elite-Headlight-Bulbs-Conversion/dp/B01H2EIKLC?th=1
You may need the anti flicker as well
Another member installed these, and was happy with the pattern and output
JDM ASTAR Auto LED Bulbs,LED Headlight,Fog Lamps & Turn Signal Brake Tail Light
He did install the anti flicker (on drop down menu)
1 - 2 of 2 Posts
