1 - 20 of 45 Posts
Just curious who has the fastest 6spd times. I would love to see all the times across the board. I know the driver is a HUGE factor, but I still would like to see some times!
^^^^^^^ yep :)
only a small percentage of 6 speeds around and going to the track
Just trying to compare apples to apples. I see a lot of hating on the Maggie 6spd times. Just looking to see what the Best blower on the planet does!
When someone posts a thread, there should be an option to let vendors in or not. This is a topic that they have no reason to chime in on, but you know they're coming....
Sure is quiet in here!
there all scared of your warranty mike
I would say there aren't many 6 speeds that have KB. TA340 is the only one that I know of. Most of the guys that want to go big, will most likely have an automatic.
I'm going big with a 6-speed, though not with a KB. Should be fun yelling "frag out" before each gear change! Im sure it will get an auto some time down the road, but I think Ill try and push some boundaries first.
Arch, where does your build stand? About to get started with mine. I'm curious how the tuning goes with that cam. Are the 80lb injectors enough with both turbos and spray? What has BB done to the 6sp?
BT you will need a new clutch with a stroker and a supercharger. stock 6 speed tranny is stout to 1000rwp, but blocking plates can cause shifting problems at 600rwhp+.
That camaro runs a built version of the 6060 tranny we have
1 - 20 of 45 Posts
