So I need some help I got the back up camera hooked up and now I need help with the front one how do I wire up the power cables:dunno: I need your help peps
No the first one where do I hook up the power cable, I had an Idea about the latter but thinks I was off on that one too:SM030:Not sure if you mean finding a power source under the hood or running from the head unit. If the latter, here are some threads on how to get the power and video wires through the firewall.
http://www.challengertalk.com/forums/f39/seeking-advice-wiring-through-firewall-55022/
http://www.challengertalk.com/forums/f202/added-front-rear-cameras-w-lockpick-126673/
http://www.chargerforums.com/forums/showthread.php?t=125941
Thanks Rudedog that's what I need to knowI run a front facing camera and it get's its power from the lockpick.
If you need a switched source, you can always tap into the fuse block - If you look at the diagram under the cover, you should see one listed as diesel PCM or something along those lines. Since we don't use diesel, this is a free fused link.
