561 - 580 of 597 Posts
Discussion Starter · #561 ·
So these works of art finally got here this week. I’m dropping them off to my professional welder this weekend to get some -10An buns welded in. Also going to tidy up the fuel pump wiring. My new 3.55 Getrag is on its way to me so that’s exciting as well. If all goes well and the wife doesn’t task me with anything I don’t want to do. I’ll start on my 3.73 Getrag gear install.
You plan on running any baffling on the inside? Only reason I ask is I have the A2speed aluminum covers and they come with baffling and a provision for a built in oil separator on the passenger side and a fresh air port (forgot the thread size) on the driver side.
Discussion Starter · #563 ·
I wasn’t planning on it. These don’t appear to have any baffling that I saw. I’m just opening them up to help with crank case ventilation.
I strongly recommend running them into a sealed catch can that has valves for manifold vacuum and pre-compressor vacuum. Venting to atmosphere isn't ideal.
Reactions: DakBuilder
Discussion Starter · #565 ·
These are getting vented into a Mighty Mouse
Catch can. Thanks for the recommendation.
2 weeks... No updates.. Curiosity is building...How's the progress?
Hey DB, I thought you may be interrested in this. Seems like a nice upgrade for the Getrag.
2013 SRT8 Getrag w/ Broken Springs & Weird Clutch Stack
Sent from my SM-T350 using Tapatalk
Ummm I’m going to pass on buying your nitrous setup 🤣🤣🤣 glad you are ok! I’ll be reading this thread for the next couple of days!
Discussion Starter · #569 ·
Here you go MCloud got the Holley Valve Covers modified. And installed.
Reactions: McCloud
Discussion Starter · #570 · (Edited)
Here’s the Passenger side this was a pita. I had to switch to different hardware then what Holley provides. The cap hex screws were too difficult to deal with.
Discussion Starter · #571 ·
All of the lubricants for the engine and diff arrived yesterday.
Discussion Starter · #572 ·
Got that Amsoil breakin oil for first start
Reactions: McCloud
Discussion Starter · #573 · (Edited)
Also picked up that severe duty diff fluid for the 3.73’s I got from McCloud.
Discussion Starter · #574 ·
I’m at the point now where I just have to install the wiring, diff, and purchase a new driveshaft(which will wait for a minute). Then I can attempt a first start and tuning.
Discussion Starter · #575 ·
Ummm I’m going to pass on buying your nitrous setup glad you are ok! I’ll be reading this thread for the next couple of days!
Buy my nitrous setup I’ll make you a great deal. I need money to finish this up I keep getting side tracked buying new engines
I also picked up another BGE block during this time.
Discussion Starter · #576 ·
I saw that thread McCloud and I have the updated clutches in my 3.55 gear setup. I also have a set for the 3.73’s I’m going to use I got from you. I will buy two more sets for the 3.92’s I have and the 4.29’s that are in the car now. This is a very good mod for those of us with Getrags no matter what gears you have.
Reactions: McCloud
Buy my nitrous setup I’ll make you a great deal. I need money to finish this up I keep getting side tracked buying new engines View attachment 1024156
I found a killer deal on a 6.4 so I was going to go ahead and get it now instead of next season... It was gone by the time I went to let my wife know... Sounds like you are finding deals all the time.
Discussion Starter · #578 ·
I’m done looking for them now. I just need to finish this thing up. Eventually one of the 2 BGE’s will be put in place of this 6.4. I’ll swap this one into my 63 Dart with a single GT45. It’s mostly for cruise ins with the wife and kids.
Reactions: McCloud
2015 SRT 392
That's a good sign that you have the break-in oil inside there. That means Good things are coming! :)
Discussion Starter · #580 ·
Yes sir
