What rims are you running and are you running any spacers? This is for RT's running 275/40 on all four corners.
I am looking at running 275's all around to be able to rotate. I currently have srt black pocket rims and a 3mm spacer up front. Im probably going with cooper rs3-s.
Anyone running a similar setup?
I know of two individuals running Continental DWs in size 275/40Z20 on all four "corners" without issue; they, however, are both SRT owners, each having a slightly wider wheel than the R/T.
Hope this might provide at least a little help !!
Regards,
Gary aka "beamg5"
You will have no issues running that size tire on the SRT wheels
Discussion Starter · #4 ·
Thanks for the info. I also have the 3mm spacer for alittle more clearance too.
Discussion Starter · #6 ·
Did you have to get longer wheel studs for that size spacer. I was going to get a 5 or 6 mm spacer all around to get a more flush look.
I tried this once on my R/T and that tire size on those wheels wouldn't fit with a 3mm spacer. A 5mm or 6mm spacer might give you enough clearance though.
From what I understand, you can run that tire on SRT replica wheels because the offset is different. But I can't speak from personal experience there.
