Yes. Zero miles should be driven on the flat. The tire will be destroyed as well as the wheel.
Thanks a lot. This is good advice. I think I am going to do this . . . . . . .Get the 12V compressor out of the trunk and air it up.
Back in the car roll your gauges to the tire pressure monitoring page and keep an eye on it.
If it is holding air, drive to the shop. If it gets below 20 psi then stop and pump it up again.
This provided that you haven't already lost the bead on the tire and it can be aired up. 4 miles? Give it a shot.
Depends on how deep your pockets are. The correct answer, as others have said, is zero distance. If it's just a nail in the tread, then it may be able to be repaired. Drive even 20 feet on a flat tire and you'll chew up the sidewalls of the tire rendering it trash. Drive further than that and you will undoubtedly destroy your wheel.How far do you think I can drive with a flat tire?
So driving 21 feet on a flat tire will "undoubtedly" ruin a wheel......I learned something new on the internet todayDepends on how deep your pockets are. The correct answer, as others have said, is zero distance. If it's just a nail in the tread, then it may be able to be repaired. Drive even 20 feet on a flat tire and you'll chew up the sidewalls of the tire rendering it trash. Drive further than that and you will undoubtedly destroy your wheel.
🙄So driving 21 feet on a flat tire will "undoubtedly" ruin a wheel......I learned something new on the internet today
Just being snarky today.....I know what you meant🙄
I was just speaking in general. Drive the 4 miles the OP was asking about and he sure would.
Seems that the tires are covered by the tire manufacturer. I doubt the Dodge would cover it. How could they warranty a tire that was deflated by some sort of damage? I doubt they'd warranty a dent in the door placed there by some ignoramus. Same Situation I'd think.Did not know about the sidewalls thing.
Great info - i am going to try the V12 after work as suggested by Slidd.
I also found out that Mopar has Roadside Assistance. They were talking about towing my car if tire is fully flat. I am uncomfortable with towing - what if there is damage?
As far as towing, most are loaded onto a flatbed tow truck. Little chance for damage.
Excellent kit to always have on-hand. I’ve used this kit numerous times over the past 20 years to fix nails in tires. Got a nail in one of my Charger’s tire last summer and whipped out this kit. Been fine ever since.
At our shop, if there is fix a flat inside, the tire, we won't repair it. Needs a new tire. At least the fix a flat gets you where you need to go without changing the tire.I wouldn't put any sealer in it unless I had to, just air it up and see if it will hold air.
