I could have sworn I saw that the 14's you can't add the factory fog lights, that they removed the option from the ecu for 14's. Could be wrong.
If you're going aftermarket, you'd just need to wire in your own switch. Little more work, lot less money. Factory parts will run you around $100-125 and then depending on your dealer could be another $100+ just to turn the option on with the star scan tool.
