1 - 2 of 2 Posts
Fore Dual Fuel Pump & FC2.
New in box, with FC2 Controller.
Fits 2011 and up Challenger and Charger, including Hellcat.
NOTE: Hellcat will need additonal fuel rails and line, available directly from Fore.
Retail is $844.00
Will take $700.00 shipped.
From the Fore website:
  • Fits 2005+ LX, LC, LD
  • Double pump module
  • Supports 1200+ rwhp
  • Use with OEM fuel feed line or upgraded fuel lines
  • Use in return or returnless configuration
  • E85 and race fuel compatible (see pump manufacturer recommendations on fuel compatibility)
  • O-ring feed and return ports (may be plugged for returnless operation)
  • Multiple fuel pump options to accommodate 1200+ rwhp
  • NEW Anodized black for maximum corrosion resistance
  • NEW Polymer pump support minimizes pump noise and eliminates electrolysis
  • NEW Dissimilar pump compatible to minimize fuel heat while retaining maximum performance
BEST POSSIBLE VEHICLE INTEGRATION
  • No permanent modifications necessary to vehicle
  • Hermetic wire pass through, absolutely no chance for fuel smells/leaks
  • OEM level sender retains original position and orientation
  • Retains complete capacity of fuel system, even at low fuel levels
Are you willing to part with the fc2?
1 - 2 of 2 Posts
