Following, I haven't done one of these yet either and I don't see anything in the service manual.
I'm going to be doing the same build here soon myself. I would say just compare the orientation with your stock crankshaft when its out.What's up guys,
Finally getting to forging my motor. I'm running a 6.1 crank and the MMX drop in piston/rod kit with Manley rods substituting the Molnars that have been on backorder (Manleys will need balancing which is necessary anyway due to crank swap).
I'm swapping the reluctor wheel to the 4 bolt, 58 tooth 09-12 wheel. I just wanted to confirm that I have it oriented correctly, I assume there's only one direction it can go? Pics below
Any help would be appreciated View attachment 1046563 View attachment 1046564 View attachment 1046565
Yea that's my plan if I don't get any clarity on here. You'd think the bolt holes would be offset so you can't get it wrongI'm going to be doing the same build here soon myself. I would say just compare the orientation with your stock crankshaft when its out.
Yep already got that and all other parts. This isn't my first 5.7 build but first time using a 6.1 crank. I'm getting it balanced next week probably so I'll try to keep updates with the build for you and anyone else looking to do thisYou will also need a 6.1L HEMI Crank Conversion to VVT Spacer Ring as well. But if you've been shopping at MMX you probably already know that.
Awesome information. It's a relief knowing the R/T dipstick goes through the oil pan. Thank you!I have the same block forged rotary in built. My block is from a 2013 Ram. My research allowed me to conclude that you will have to use an oem r/t car oil pan. On a Ram, oil dip stick tub has its origin on the the driver side of the block and on a 5.7 r/t car late model has its origin on the passager side in the oil pan. So remove the oil dip stick on the Ram block, plug or fill it and swap the oil pan and gasket with a 5.7 r/t car oil pan and gasket. So will have to swap some other parts on the Ram block from your origin block.
After looking at how it was on my donor block it looks like the way I have it is correct.I'm looking into going down this path myself with the 5.7 truck block. I just located a 2013 5.7 block close where I live.
JD, did you ever figure out the orientation of the reductor ring?
Yea I should be able to get away with just boring it .010 over for the 3.927 pistons. I just have to now exchange them since I originally ordered 3.917 pistons.I'll take a closer look at the pics you posted with the crank/reluctor wheel and set mine up accordingly.
Are you still going to be able to use the block? I thought you bought drop-ins.
I have a little room on the pistons I went with. Going over to 3.927.
ouch! how do the piston skirts look?Yea I should be able to get away with just boring it .010 over for the 3.927 pistons. I just have to now exchange them since I originally ordered 3.917 pistons.
Here's pics of the scores in the cylinder walls- View attachment 1047807
They're really not that bad and most of them you can't even feel, but I'm gonna do it right the first time
Pistons skirts look basically identical to the bores, some really light scoring but nothing too deep. It seems like the cylinders closer to the front of the motor saw more wear than towards the rearouch! how do the piston skirts look?
Making progress?Yea I should be able to get away with just boring it .010 over for the 3.927 pistons. I just have to now exchange them since I originally ordered 3.917 pistons.
