Well, I sold my 1990 daytona rwd project:disgust:. The good news is that means it is time for a forged low compresion rotating kit from PWR. After talking to 70TA and PWR, I am going to stay 345cu, lower my compression a bit, upgrade my valve springs, anxiously await for someone with a 15lb brain to make some cam phasers/cam timing limiters for this damned motor.
Plans while the motor is apart are: ceramic coat stock (slightly modified) exhaust manifolds, high flow cats (sell the entire longtube headers I have now), upgrade fuel delivery, lightened flywheel, clutch, nitrous, possibly upgrade the turbo to a 80mm BW (or at least install a divided turbine housing with quick spool valve)..hope I have the $$ left for the turbo upgrade! :pimp: then I will snap my axles and do those!
Arrington 392 stroker 5.7
USMC,
Hey I just put an Arrington forged 392 Stroker with Vortech SC, Kooks long tube headers, high flow cats, SHR tranny, 2800 stall converter,1400 DSS axles, and AJ tuner tune . 576 RWHP and 603 RWTQ ran 11.34 in 96 degree weather. The car is very streetable. They build a mighty fine engine and back it up. Plan to run the 10's this weekend at the Mopar Nats. Good Luck with your build
Iron6
Congrats, make sure and post plenty of updates!
Discussion Starter · #5 ·
UPDATE:
Attached is a pic from a week or so ago, line hone in progress. I sold my longtube headers and high-flow cats 2 weeks ago. Got a set of stock 6.1 shorties, have high-flow mids/cats on the way. Arrington camshaft and arrington heads are sitting in the garage awaiting install with 6.1 ported intake manifold. Arrington dual fuel pump installed. Umm, what else? I probably going to scrap the plans to move the turbo up to the trans tailshaft (like the RDP v6 setup). Not sure I can debug the 02 sensor gremlins with that design (I live in emissions area). I may just continue with t6 rear mounted 76 or 80mm with QBValve idea.
Decisions decisions. :blowingup:
