There are no Forged parts at least in the sense you are referring to.
The most common failure will be the piston.
How much power are you trying for. This will determine the road you need to go down.
You can put a SC on your car as it site. You will end up around 475-500 RWHP.
It will be somewhat safe. The car will be a great street car and a lot of fun to drive.
Try and look to the future and what you want to have. Doing things twice costs more, but also spreads out the money spent over time so it helps some.
What does that mean? According to Dodge the crank is drop-forged steel and the rods are hot-forged (steel). Is drop-forged and hot-forged not the proper type of forging for forced-induction? What type of forging process should be used?There are no Forged parts at least in the sense you are referring to.
For forced-induction set-ups, the pistons would probably be the first to go because they are not forged. But if you're not super/turbo-charging, does forging the pistons really matter? Maybe 5% of the members on this forum have forced-induction systems on their cars. Forum members are the HYPER-enthusiasts of these cars. So I'd guess that only 1% percent of total Challengers would have super/turbo-chargers. I'd say that that's not enough of a demand to warrant forged pistons. But thankfully, there's an aftermarket...The most common failure will be the piston.
No link, but...
Boatman, I get your analogy. IF you super/turbo-charge, replace the weakest link: the pistons.OK I will clarify.
Look at it this way, you need 20 feet of chain that holds 10000# 99 of the 100 links needed to get you to 20 feet are able to hold the weight but one of them can only hold 5000# The 99 strong ones really don't do you any good.
If you SC you could have problems if you do have problems most likely it's the pistons. If you forge to get stronger you then replace all links. Hope this helped you understand what I was saying.
Where and what sizes?I have these wheels for sale.
I'm in Wyoming the wheels are here. 8.5x20 fronts and 10x20 rears. There brand new I did mount tires on them but they have never been on the road.Boatman, I get your analogy. IF you super/turbo-charge, replace the weakest link: the pistons.
For N/A setups, do you think that the stockers will do ok?
Absolutly fine they are fine for a moderatly boosted setup that is tuned good also.
When I put my Maggie on they did a stock dyno and that came in at 350. After I put it on it went to 511 also had a CAI and catback.Magnacharger quoted me around 120hp/120tq increases with their new 392 supercharger. Of course they are finishing the tune.
No link, but...
Mopar Action wrote an article called "Meeting the Challenger" this year. In it, on pages 26 and 27, they wrote up most of the specs on the new motor.
"Besides the obvious displacement increase, which was acheived via a 0.145" stroke job and a 0.035 bore, the block continues the Chrysler tradition of top-quality materials, being cast from premuim G3000 30KSi iron; deck height is raised a tod to 9.284". The crank is, of course, drop-forged steel, and the rods are also hot-forged. The heads are all-new..."
