1 - 17 of 17 Posts
I am adding a front camera to use with my tazer. I have tested the camera, got it working and routed wire through the firewall. Just have to mount the camera. However does anyone know what these connectors are called?
990108
They plug into the back of the wire harness. And I should use them to make the install more secure.
990109
After I am done I can do a write up with pics if anyone us interested.
2012 Charger Pursuit
Pins?
When they’re inside the wiring harness plugs, it’s called a pin-out isn’t it? That would make those pins I think...
That’s my best guess.
Something like female spade connector/terminal. Are they flat at the end or round? They are usually classified by wire gauge. Do you know which connector you are looking to attach them to? Generally connectors in a connector are latched...that is they lock into place and you have to push on a tang to release them.
Possible Tyler or Chllngrswpr or RMassa187 can point you in the right direction
If I can guess...
It looks like you intend to add to an existing connector on both sides?
Probably NOT worth the trouble.
Pass the wires through the large bulkhead bellow without connectors, and add and connect them inside the cab.
You will probably never remove the larger connector, and it will only confuse the next user.
No I have all the other wiring routed. All I need is the final connection from the stripped wire into the back of the harness connector that plugs into the radio.
Zautomotive sells this but it is $25. Just thought someone might know what these connectors are as they probably cost 2 cents.
Salvage some from a junkyard car, and pull out the wires and solder your new ones in.
The mopar connector repair kit link I posted earlier would probably be just as expensive if not more but it would have the correct wire termination.
Even summit charges like $30 for wiring. Best bet is junkyard like Pioneer4x4 mentioned.
Thanks for the advice folks. I had a look around in my garage and found an old wire harness that came out my Jeep when I swapped the factory stereo. The pin terminals looked a little shorter but they fit perfectly.
Still need to mount to camera and tap a power source from the fuse box.
If you don't have A8 and Tech with the radar unit, that would be the obvious choice with factory lower grill. (not my car, found it on the web...)
Discussion Starter #13
Finally finished! Little bit annoying but something anyone can tackle.
990669
990672
So quick overview of my install.
1. Install camera on rear of stereo. I followed the Work Play Drive youtube video for this part.
For the connectors that go into the back of the wire harness you can probably salvage from any old radio. Zautomotive sells just this connector but it is pricey.
I found a wire harness from my 2010 Jeep stereo. I was able to pop the small connectors out using a sewing needle. They were shorter but still worked.
2. Run wires through firewall. So this was the most annoying part.
Start in the engine bay. Large rubber grommet behind the engine accessed from passenger side.
990678
I used a long thin screw driver to poke a hole. It required quite a bit of force. Once through the first grommet there is a gap and another hole. You just have to wiggle around until you get through.
I then got some wire and a coat hanger. I used bright colored tape to fasten the wire and pushed it through the holes made by the screw driver.
Great tip here is to lubricate the end to make it easier to go through.;)
990679
To access the other end you need to go under the passenger footwell. Remove the panel underneath the glove box. Disconnect the footwell light connector.
990681
So for this next part I lay on my back looking up where the arrow points under the glove box. You should be able to see the wire you poked through. Again use bright colored tape. It is hard to access but an assistant with small hands will help.
Pull the wire down let it dangle in the footwell.
You can feed the wire down from the stereo into the footwell pretty easily. Then tape the wire and pull the wires back through the firewall. Again lubricate to make it easier.
3. Wire camera to power source. I tried fuse taps into the fuse box under the hood. For some reason my camera would not power on. I just wired it like this for now with an inline fuse.
990685
4. Install camera. I wasn't sure what to do about this until I finally just went for it and drilled a hole in the lower grill surround. I was worried I might screw this up and I wasn't sure if I could even get the camera wire through here but it all worked out and I am happy with the look.
My camera came with a slim connector that I could feed through the hole and into the space behind the lower grill. I routed the other end of the wire down the gap between the radiator and the top of the bumper.
990686
Last part was just tidying up the wires and lining up the camera. My camera came with a little alignment tool so you can fine tune once the camera is fixed in place.
Are you running the original 2.4.5 firmware or beta 1 or beta 2? My experience with 2.4.5 and 2.4.5 beta 1 is that they are extremely glitchy. In fact 2.4.5 (there actually were two versions, one was 031320r and the other was 031420r and is the one you can still download) won't run on my 2015 (that is the 031320r which was the very first version to hit the site but is no longer downloadable). Have yet to try beta 2.
Discussion Starter #15
I have the original 2.4.5. I think I downloaded it the day it came out. I recall someone saying there had been a file put up then taken down again though.
I haven't noticed anything untoward so far on my 2019.
More pics.
990689
Super close without touching!
990690
Discussion Starter #16
One more thing. I also used zautomotive's Jeep JL front camera instructions for the stereo wire hook up. I used pins 24 and 25 as below.
990691
Yeah, the very first 2.4.5 had a file name 031320r which just plain did not work, the following day they made 031420r available. Then a day or so later beta 1 was available and I noticed it would cause eco (I have a manual so this should not show) and sport to act up. The other day the made beta 2 available. Maybe it is my tazer (2 years old) but another member posted other issues (link is in my previous post).
1 - 17 of 17 Posts
